- 26 Sep 2017
- In the Masonic Temple
I love how as soon as i suggest a kind gesture for Xmas to someone that has helped probably 100's of people this place becomes a ghost town.
What is not working properly for you? Can you explain some more, maybe we can help?
I use a LC bios on my V56 water cooled.
I'd put that down to driver confusion ?
why run such an old card at the same time ?
pull it try again get rid of NVidia drivers .. ???
amd NVidia don't play well together
Ok, so now im almost 99.9% positive its my PSU. I after flashing the LC bios I set power level to -25% and Unigine Heave did not crash for like 30 seconds and if i set my power level to -50% it does not crash at all. i guess i will have to wait until i get my new PSU
Are you using the latest Adrenalin drivers? IF you are DDU them and go back to 17.11.1. See if you still get crashes.
Sure am, ok i will try that when i get back to the house. Thanks![]()
Just curious did that work for you?
I am certain that there is something wrong with the Adrenalin drivers. Because I get the same issues as you with the Adrenalin drivers but everything works perfect using the 17.11 drivers. I ruled out the PSU as I hooked up two PSU's to my system, two 650 watt gold.
Just tried it and it does the same exact thing.
I hope its the PSU and not the quality of my GPU chip fabrication. just will have to wait until wednesday (well friday when i hook it up) when i get my EVGA 1200 watt PSU
Did you run DDU in safe mode before installing 17.11.1 drivers again? If you just roll back the issues persist. Damn, thanks for trying, sorry it didn't work youDid you run DDU in safe mode before installing 17.11.1 drivers again? If you just roll back the issues persist.
It's just funny that the problem started after update to Adrenalin drivers.
Hope the new PSU solves the problem.
It's all good, i thank your for the suggestion it was worth a try and i hope the new PSU works too as it cost me $300. And yep safe-mode and everything. I actually had better experience with the Adrenaline drivers then any of the 17.11 series, i think the new features are great (better then NVIDIA's Geforce-Experience overlay even) Cudo to AMD. But if i were you i would try running AMD Clean Uninstall Utility tool then DDU and give 17.12.1 Adrenalin a try again
I have actually tested two Vega cards in two different computers over the past couple of days. They both work fine in 17.11, both have problems with 17.12.1. With one I even went to the trouble of doing a complete reinstall of windows 10.
