- 19 Oct 2002
- Shakespeare’s County
Is it comin to Santa Pod?
Well a bit of slip and drift aint bad eh. Heightens the fun factor.
Curious as to what Gibbo’s role is at OCUK now. Not fishing for salaries and what not, but how senior are you? Do you own this place? (With a car like that)
Great choice but the way.
Lots lighter too. Those wheels are forged and something like 3.5kg lighter! Rears have a seperate smaller caliper for the handbrake to bare in mind too.
does that seller pinch cars then break them down lol![]()
Did you mean the wheels are lighter, or the brakes?
Actually i think Im thinking of the F Type R when you spec ceramics and option of forged. I think SVR is forged as standard.
From Website
Weight is the enemy of performance. So we designed F‑TYPE SVR to be as lean as possible. Every gram has a purpose. Its lightweight Titanium and Inconel® exhaust system saves 16kg, while the striking Forged alloy wheels offer a 13.8kg overall weight saving. Each redesigned rear suspension knuckle shaves off 0.6kg compared to conventional knuckles, and the optional 398mm front and 380mm rear carbon ceramic brakes reduce weight by 21kg compared with non‑ceramic alternatives. Every milligram saved gives F‑TYPE SVR more rapid acceleration, more agile handling and sharper braking – for an unforgettable driving experience.
