All the Trials are now available in game btw. Enjoyed running through them yesterday. You seem to be able to re-do them, but only get the item rewards once.
Fantastic looking game but also a hardware ballbuster. Finding that its best to disable HDR as well that saps a lot of FPS & also makes some desert sections blinding white so much so that you cannot see anything at all its overpowering they went to OTT on the HDR so you cannot even see the gfx properly at times. AA on adaptive also works best FPS wise & resolution also plays a big part. In cities the FPS are a real slog but outside in the desert the FPS are much better so lose some people from the cities as well helps a bit.
I mean Adaptive AA. Dynamic Resolution is a waste of time if you have a native 4K display as it keeps dropping to 1080!I only have the normal AA settings low/med/high/v.high - do you mean set dynamic resolution to 60fps?
I bought this last night and played for the first time this evening, 2 hours in and I'm on my way to Alexandria or whatever it is.
I'm struggling to get used to combat, I can sneak but I'm pretty rubbish at close combat.
Looks fantastic, it's munching my system up though, my poor little 1060 is needed to be upgraded me thinks.
I made it to Alexandria last night and my 6700k took one helluva pumping. She runs at 4.4GHz but even that speed couldn't satisfy demand. It's the only time I've seen 100% on every core out with a benchmark or video edit.
