- 6 Dec 2013
- Nottingham
Presume you tried ddu already?
Any chance you have reshade installed?Sorry for the double-post;
Here's today in PUBG: https://www.youtube.com/watch?v=Z7jU5PbW4Mo&feature=youtu.be
As before, haven't touched WattMan settings or altered stock in any way.
You could try run it at 120hz? Maybe the monitors overdrive could be causing the artifacts.Nope.
I went ahead and nuked my OS install and reinstalled. Ran PUBG fine with no issues at 59Hz Monitor on my 144Hz monitory (weird, right?), but I just set it to 144Hz and now I'm getting the issues again.
Going to set it back to 59/60Hz and see if it's back.
If this is solely caused by 144Hz then is there any way I can avoid it in other games, aside from swapping back to 60Hz? I bought this monitor to enjoy the higher refresh rate...
What monitor is it?
I didn't think it could be those, since it comes up when using desktop capture. But is worth a try.Can you perhaps try different monitor cables. Sounds like a long shot but nowt to loose atm.
I definitely think it's a faulty card. Especially since it appears on video capture.
One last thing to try is maybe an undervolt? Maybe your power supply is too weak?
If doesn't work probs just RMA again. At least you know not to buy from them again.
If it's running fine at undervolt might be a power supply problem.I did try it, on the off-chance. Didn't make a difference.
Currently running the card at: 1537 S6 Freq, 1642 S7 Freq, 1050mv S6 & S7 on GPU, 880MHz Mem Freq @ 1000mV Memory and +50 power limit.
No crashes yet. Did get one hang in PUBG, but no artifacts yet.
Using a EVGA Gold 750 PSU - it's about a year old. I double-checked all the cables to all components when reinstalling the card.
If I decide to RMA again, I'll be sending a ton of videos and images to them. I just find it so strange that this is happening on the stock settings the card came with.
I don't know of any way to test other than having another PSU, but usually, if the card runs fine at the undervolt it means that the PSU can't supply enough power or current to it - causing the artifacts you're seeing.Any way that a noob like me can test that out, other than buying a new PSU? I went ahead and built the parts up before upgrading on ************ - which gave a estimated voltage of 449W.
Checked Amazon out of curiosity, and turns out I bought the PSU in 2014 if that has any relevance.
I might begin to put aside some ££ for a new PSU anyway - any recommendations?
For recommendations: I bought the Corsair HX850 on Black Friday for around £110, and it works great; the fan has never needed to spin even under gaming load. I got an i5 8600K at 5Ghz and the Vega 56 at 1050mv, (for reference purposes).
Are you able to test the card in another system at all, the fact the dots are appearing in video capture which bypasses the video cards VRAM, points toward it being either PSU issue or even the motherboard. If the supplier are stating it showed no graphical artifacts at all in 110 hours of testing, then it could well be something else.
As you have already tried a fresh install of windows, that rules out a software issue, so its almost certainly hardware.
