Does anyone know if the Ryzen+ chips coming this year will have better memory support or will it require a new board and chip? Gigabyte say my board should run my RAM at XMP but it refuses to play ball![]()
In short, everything so far points to yes, better memory support to come.
The new chipset shouldn’t have anything to do with it. I’m sticking with the CH6.
Thanks for the info, any idea what I'd likely experience if my CPU was faulty?Unless you are going to do large C++ compiles under Linux then you won't really experience the issue, it's pretty isolated.
You should be fine for general use, your CPU could be perfectly fine too, not all pre-week 25 Ryzens have the segfault issue to begin with.
Nothing really, unless you do large C++ compiles under Linux![]()
I have a week 9 R7 1700 and I do have the segv issue but I've never experienced it under Windows. Any crashes I had in Windows were due to unstable overclockes (too low voltage on the CPU or DDR4 timings were unstable).
