Fun fun fun! What kinda mileage has that seen?
as best I can determine, about 10000, a great many of them being wet miles in urban conditions - 23 sets of lights on my normal 5 mile commute route
10000 miles to a set of brake pads? Nice
Haha yeah, 10000 miles to a set of pads but wore 3 rims... Might need to rethink those pads made of borosilicate (or whatever it was they coated the space shuttles with)!10000 miles to a set of brake pads? Nice
I've swapped my winter tyres front & rear the last couple of times. Didn't seem to make much difference with the GP 4Seasons as the previous rear (fitted to the front) wore through pretty quickly. The harder Spesh Roubaix Pro I'm using now it's worked well so far (about to complete their second winter and still tons of wear left!).not sure how many pads but the tyre I took off was the fourth or fifth (i'm not sure because I occasionally put front tyres on the back after a while.)
Ewwww! Quicker to walk!23 sets of lights on my normal 5 mile commute route
Yeah but only to even out the wear so I could change them both at the same time rather than running odd tyres. Although looking at them they'll probably easily do another winter!Roady, you swap tyres from the rear to the front?
I'd imagine it's more likely people do that as rears wear quicker but I'd strongly advise against it. Worn tyres are better suited to the rear where a loss of traction matters less
Jagwire. Last time I bought 10m lengths from 'STARCYLES' on Ebay. They're branded and perfect! Came shipped from somewhere in the midlands and IIRC with some bike shop kinda packaging. Unsure how they're able to sell it as cheap as they do.Sure I've asked before but what gear/brake cable inner and outers are people using? I need to replace on my 105 and ultegra bikes - I've previously used jagwire but not convinced £60 for two cable sets represents value for money. Similarly the lifeline stuff from wiggle is just burning money - it doesn't work.
the 13 mile "long way round" doesn't have any at all between mile one and mile 9, and only about 8 possible stops in total. As a result it's considerably less than twice as much time even though it's well over twice as long
NVM, found it. Still reads as if I need to wait to see more than 193 of my rides. Le sigh.Anyone who's not yet registered on www.wattsboard.com and was intending to can you do me a favour please, when you do part of the initial setup it talks about the number of rides it imports from Strava and the timeline/timescale. Could you grab a screenshot of it for me please?
I can't get mine to update,add new or older rides and they've not responded to my support question yet.
I'm at 6 days.Please allow up to 24 hours for all of your rides to be imported and processed.
Due to the current user load, we are limiting the number of rides that you can import. The following tiered import limits are in place:
Within the first 24 hours after signing up, you can import 50 rides. After 24 hours, you can import 125 rides. After 3 days, you can import 350 rides. After 1 week, the import limit is lifted.
You can currently import 151 rides from Strava. Go Pro to access unlimited and priority imports.
Yeah but the 'bulk upload' is only 50 rides which it takes 15 minutes to process after you 'select all' and click 'Process'. After 24 hours it's 125 rides (which will take ~37 minutes to process), but you still need to select them and click process for them to appear, etc etc.Just did a bulk upload for mine.
My ego is very satisfied with knowing I'm apparently a Cat 1 category for 20 min power!! (I doubt it!!)
Gutted! Are you planning to trip back at some point? Eventually live out there again?
This picture pretty much sums up UK winter outdoor training.
My short time intervals are pretty pants, I need to work on sprint power. I'm much better at longer power intervals, hence why I want to get into time trailing.
