The I2C access to VRM is still an issue. By default HWiNFO will not access VRM via i2c, but it can be forced. The driver does support giving VRM temp info without i2c access, I believe AMD ADL is used, Martin would be able to state. In
linked image left image is non i2c and right with i2c.
Using non I2C access the VRM temp info will sometimes be there other times not, I could be doing monitoring for 24hrs+ continuously and it will not appear, here is a
37hr run.
Using I2C access can mean GPU get's disconnected from rig (ie blackscreen, no GPUtach LED, reboot needed, etc). This occurrence correlates with just accessing VRM info via I2C (ie when you just open HWINFO). I can go few days without issue occurring or have it repeatedly in succession within minutes.
It does not matter if card is stock or OC'd, what VBIOS I use, etc.
I2C access = possible GPU disconnect from system, non i2c = hit'n'miss if I will see VRM temp info but never will GPU disconnect in testing so far.
AMD keep stating to Martin it is fixed but it is not. Please can this be highlighted and resolved, thanks
