- 14 Jul 2005
- Birmingham
The Tdie in HWInfo is the correct temperature. So idle at about 29 degrees
but in the first set of screens its showing 44 degC. the system was at idle both times.
I don't know whats going on here but Im not happy really.
Firstly, this is just at idle - nothing is running except the monitoring programs.
1. All the four programs display different temps? Which is right?
2. Look at the monitoring in afterburner - why is the CPU sawtoothing like that at idle? Ryzen master shows the CPU jumping up in clock speed every second or so.
3. Temps are all over the place - not one of those readings is stable. Jumping around between 44 and 50 degrees.
4. 44 degrees is a bit high for an idling chip isn't it? Granted, if it is 44-50 at idle, then to be 52-58 under load is pretty reasonable but why is it so high at idle? My previous i5-6600k was 23 degC at idle.
*snip*
A few mins later I get this with HWinfo running alone. It now says 29 degC against TDie, 49 against the one above and below in the other section 41!
*snip*
They'll let any riffraff in here wont they...
Just a FYI though,
Only 8 core in here, Sorry
Elitist
BTW, what is "AM4 Advanced Boot Training" ? ASRock AB350 Pro 4.
It helps with locking in higher memory settings. You might notice it boots twice (possibly more) to lock in the memory with it on. If you dont like that and your memory speed works without it, turn it off.
Bug, about god damn time!
Welcome, now clock to 4Ghz 3200Mhz CL14 fire and forget.
You'll have to give him some time, He's old ect, He's still a little confused with all the threads he now has![]()
Wait till April and see what Ryzen refresh does, if you are mostly gaming then a 8700k is probably the best bet.Has the Ryzen/motherboard/bios ecosystem settled down?
Am thinking of chosing AMD over Intel for my next build and am wondering if the early teething troubles have been ironed out.
Haven't run an AMD chip since Barton core and the focus will be gaming with a bit of 3d modelling.
1700x or 1800x partnered with Crosshair 6 a good choice? Ideally 16gb ram as minimum. OC capability would be nice. (water cooled)
