Bet @Plec could have linked that and still wouldn't of worked hehe
Yep, third party apps hate me - and i hate them right back. Or they would if i allowed them on my system, the %#$&'s.
This thread hasn't renewed my faith any...
Glad I can help, RGB all the things.....!
Too fast!? okay I will feed that back to HQ Orbital... as it happens I am currently sending some recommendations on BIOS so will add that in.
Hey @leeince - glad to read a post that's all positive, you deserve it.
I bought the exact same joystick for the exact same game (3 years ago) - i can't comment on the game as i never got around to playing it properly but the joystick is great quality. From the bits i did see it should be fantastic experience using VR.
I'm thinking of buying one for my kids - as Google Earth looks great and i'm an F1 freak so i'm interested in VR driving games but i'll probably get nauseous using it. :/
Hey @leeince@Plec @orbitalwalsh
I was playing battlefield today, i wad only playing for about 5 minutes and the pc crashed, screen went black and the no signal message came up. I restated the pc and tried again and it happened again but a bit longer this time. On both occassions there was a lot going on on screen with explosions and things, any ideas what this might be? And what i should do to stop it?
Hey @leeince
Is the crash 'game specific' or is it replicated in any other games?
You'll need to run a few diagnostics - most obvious being your CPU and GPU temps - do you have any monitoring software and a couple of synthetic stress tests (i think you have core temp)?
We need the idle temps of both the CPU and GPU and then again when under load - this may have to be done/observed quickly if it is a thermal problem.
For speed try a couple of brutal synthetic tests - prime 95 for stressing the CPU and MSI Kombustor (you'll need to scroll down to the bottom of the site to get to the link) for making the GPU sweat.
Have the monitoring software running at the same time (Kombustor will do this within the software) - watch the temps closely. If it's thermal issue it will show up very quickly - likewise if it's a fundamental component flaw (but not always guaranteed) - but we're really just exploring temps for now. You will only need to run each test for 15 minutes for thermal testing as both will stress each component far more than any game so the heat generated within the cores will be very quick.
The other test you may want to consider running is memtest - this will tax your memory but unlike the other tests this is best left to run overnight unless it gives up errors straight away.
Hey @leeince
I also turned the fps counter on in the nvidia experience earlier today and that shows 200 fps in sims when my minitor is only 75hz?
Try 'Stress Test' option - if no joy you could try a reinstall (but you are missing a .dll file) or if that fails you could run Firestrike instead (most people preferred choice) However this is a much bigger app but will still will push the card but with added panache - plus bragging rights if you register.Those are the messages I get when I try to run real bench. The system error comes up immediately and then when IO click ok I get the instability detected down the bottom.
Any ideas?
My little boys currently playing sims4 without issue so far. I dont suppose sims is very taxing but my temp while he is playing are cpu 47 gpu 52.
My little boys now playing unravel, again i doubt its very taxing but its playing without issue.
Missed this.I don't know what settings I should be using on prime 95 or kumbustor
No problem - and those temps are fine.@Plec at @orbitalwalsh
I was just playing the division at 2556x1440 @75hz all on ultra and it run without issue. Both gpu and cpu were around 61c, is this ok?
I was running the "stress test option when I got dll message, its confusing because the one you pic turns grey and the unselected one turns red, it looks like I've selected benchmark in the pics because its red but its actually the stress test.
I wll try firstrike tomorrow and also the ram voltage, you will need to talk me through the ram voltage if you don't mind gents.
Chat soon,
