- 6 Feb 2008
Exactly that! What I've paid is pretty much almost half price!
Are you able to link me to the seller that you used? I'm after a couple myself and it sounds like you've done your research.
haYou make it sound like I know what I'm talking aboutha
I got 2342s from XinRay Store and 2335's from HIK Security Professional Store
Keep an eye on your aliexpress messages as they will message you there with regards to shipping info.
Can't say yet as they haven't arrivedOut of interest did you get stung for import at all? Did you buy them all in one bulk order as separate deliveries?
All in one order (from each store)
.No worriesSaw your email, awesome. Thanks for the heads up.
...Which dahua for low light equivalent of hikvision 2335?
What kit do you need for recording on one of them then
So two of my aliexpress cams arrived
For best security should I port forward stuff manually on non default ports... Or use hikconnect? Which I believe is for remote access.
Already have ddns so don't need hik to provide that.
If manually, is it just the server port that needs forwarding? 8000 by default from memory (I changed it)
Download VSPlayer, that will show you the lines and should give you some rough understanding of what's going on.Am I missing a trick with Hikvision motion detection, have had the cameras set up for 2 weeks now and capture plenty of events. A fair few false alarms but that's a compromise on sensitivity level.
I set off for a ride this morning crossing my drawn area, no problem - recorded. I came back this morning and rode through the very same area but the camera recording wasn't trigged. My rear camera covers the back of the drive which did activate. It's not a small area either and one that regularly captures cars & pedestrians.
The front camera was recording moments before due to changing in cloud covers/light and a bush blowing like the clappers. It did also pick me up a few minutes later walking back round the front to let myself in.
So I'm unsure why the front would have missed me with the rear picking me up seconds later...
ThanksFor best security, use a VPN. Using non-default ports is not a security measure.
I'll be honest for most domestic settings, we setup port forwarding and usually use HiDDNS.
For SME+ we tell them to use VPN.
You need to forward all the ports for everything to work.
