- 22 Jan 2014
I forget the town name, but it's the only monastery I've found (thus far).hrmm im back on this today as i havent done 4 of those u mention haha. The monastery in rattay?
Damn it! The one side quest I was making progress with is bugged. The Nightingale one. One of the cages has disappeared. Thats a waste of an hour!
Some of the screenshots i have seen from this look so DAYUM pretty!
Unfortunately the final game had to be deforested a bit in order to fit into memory of low end PCs and consoles.
Regarding the downgrade, it is true the beta had even more vegetation. Unfortunately the final game had to be deforested a bit in order to fit into memory of low end PCs and consoles. This is normal though, during development you build the world and optimization comes much later.
Not sure waht armour you have, I found a pretty decent set and used that. Still had to do it a couple times because I DO suck at combatEither I suck at combat (most likely) or the bandits in Ginger in a pickle are nails! Tried it about 15 times now...
, and also at this time in the game I done no traning with the Captain either. But if you want to get bit better armour (unless you already found it) you could go here if you want, then try them again. I did have most trouble with the Axe wielding guy though.
fancy sword man is willy waving his stabbing stick around like zoro.
It's the axeman that shreds me! I've tried to bow him but he takes about 5 arrows and by that time the fancy sword man is willy waving his stabbing stick around like zoro.
Thanks swede I'll check out the armour, I've only got the paltry starting gear really, I want to do this quest then start roaming a bit.
