I use Zwift on an iPad Pro and it works fine. Delete the the app and re-install it.Ever since Christmas and an update that came out at that time, iOS app has crashed loads for me on an iPad Pro
Do you need to register with WBR for their races? I did one yesterday lunch (really good race actually) but I’m only in the unfiltered results on ZP (I am registered on ZP).
Is that sort of average HR inline with your past efforts? I know they can be funny with certain results. My mate had loads of problems proving he could match his numbers.Smart trainer, HR monitor!
Has a grey HR box similar to what is used of over the W/kg when you get DQ.
Average HR 173, max 193.
I think you have 2 separate 'issues'. The HRM related one sounds like a communication or contact issue. Well worth changing your HRM battery and also refitting the strap so it's tighter and able to maintain contact with you. The fact your HR is high shouldn't make any difference to the HRM's communication.I have as strange issue whenever I do a workout on Zwift.
When my HR approaches max rate my Tickr HR monitor drops out and the picture on my TV slowly gets more and more fuzzywhen I stop the workout my HR monitor comes back and the TV returns to normal.
Raise a ticket with Zwift. There is a way to recover the part files (like '.fit files on a PC) which you can then upload, but I'm unsure how that works on iOS. There is probably a log file their support will request from you, which they'll give you guidance how to retrieve for them, but the simplest start point would be a reinstall. At least that is within your control!Ever since Christmas and an update that came out at that time, iOS app has crashed loads for me on an iPad Pro. I lost an hours ride again yesterday, no idea if it's a specific use case that causes it but when I hit Save to upload to Strava, it either immediately crashes to the iOS home screen, or just sits on saving forever and I can't do anything so have to force quit the app. Yesterday was the latter. 9/10 it doesn't even let me recover progress when I restart, will just say there was an error, or it recovers like 5 minutes of the ride. RAGE
So frustrating because I like to keep track with stats on Strava, especially as the weather is improving and I'll be cycling more regularly, and because if it's not on Strava, it didn't happen. I don't think you even get any fitness benefits from it if you're body knows it didn't go on Strava
I'm tempted to a cheap rig for the garage that will just be a Zwift box as it will be a lot more reliable and at least if it does crash, I still have access to the files.
You only need registration with ZP. When the race is finalised you should appear in results unless there is a problem.Do you need to register with WBR for their races? I did one yesterday lunch (really good race actually) but I’m only in the unfiltered results on ZP (I am registered on ZP).
You have to make sure you have compatible devices to run on mobile. Also you can only connect a certain number of devices to the iPhone before you need to consider adding other kit to make it work. I’m personally using an old computer and tv that’s setup permanently in a converted room in the cellar.What do people use to run Zwift?
Is there a difference in functionality between the different devices?
I’ve got an iPhone I can use or an old laptop which I think meets the minimum specs.
In time I’ll pick up a cheap tv off Facebook so I can either connect my laptop to it, stream to it from my phone or pick up an Apple TV to run the native IOS app on that.
I’m leaning towards streaming from my phone as then my watch connect to it and will give me heart rate readings, but wondered what others used/recommended.
I use an iPad Pro and it runs perfect. The only thing missing from the higher end laptops/desktops are the shadows.What do people use to run Zwift?
I did the 5:15 one. It felt like I climbed way more than what it reported!I've booked onto the Zwift WBR 3 laps hilly race which is 17 miles and starts at 9.15pm tonight - if anyone is interested I'll see you there!![]()
Probably if my turbo wasn't a road machine...Couldn't you manage without Di2 with ERG mode enabled in a workout?
Think I've persuaded the other half to let me bring the turbo inside for a week or so, although will mean the only time I can turbo is prior to 6:30pm due to baby^bedtime. Still if I get a snow day tomorrow/friday I'll be on the turbo, if it remains in the garage I won't as it's just too cold...!
It didn’t prepare me for Zwift though. I chose the hilly map and was knackered after about 5 mins
