It's a GT and not an out and out 'sports car'.
The reviews I have seen have praised it and it has surprised on track.
The gearbox has been praised too.
It does exactly what its been built and marketed to do. Might not be for everyones 'tastes' however...
Worth watching:
I looked at RC Carbon and LC500 Sport Plus as an alternative to the Mustang. I dismissed the RCF pretty immediately due to older gear box and just not liking it so much. The LC500 in person is very marmite, from some angles I loved it, but from others it just looked odd, but one thing guaranteed is nothing else looks like the LC500 on the road. I shall start with the good stuff, the interior is amazing, way better put together and much higher quality than BMW and even Audi, but to me I get the car is a GT but its also trying to be a sporty GT and as such it came across to me that the car is trying to tick too many boxes. The 10 speed gear box is good, responsive and makes great blips on downshifts. Engine is quite a peach too, but needs to be revved due to the weight of the car.
Problem for me with LC500 was it was SLOW, even with the fast 10 speed box its a 5s to 60 car. Then in Sports Plus specification it was nearly 90k, though Lexus will discount them to close to 80k, but I was comparing it against a 2018 Mustang and it just failed to impress. Over £30,000 more, around 250kg heavier, also the Coyote gen3 engine is better, a lot more available torque across the whole power range and revs even higher than the Lexus motor. Lexus 10 speed makes nicer noises, though the Ford/GM 10 speed shifts faster. Of course the Lexus is in another world on the interior, though the 18 Mustang digital cluster is nicer.
If money is not a real issue or depreciation and your main plus points are having a super rare car that is incredibly well bolted together with a stunning interior and makes a good noise the LC500 is a good car.
But if your more performance orientated for me the 2018 Mustang even with its poorer chassis but with mag ride is a more fun car handling wise and its a quicker cars, 1/4 mile on an A10 Mustang is like 12s dead, whereas LC500 is around 13.5s which is a big performance delta.
Plus I enjoy modding, Mustang has huge potential, Lexus on the other hand well forget that.
For me the Lexus is very much a GT, the sports part and performance part is minimal, of course to some it maybe amazing but it really depends what your used too and your priorities and for me its more about performance, every day use ability and sound/rarity.
The other car to consider is the Alfa Quaddroflfofodkjhflkjfsdlkjflkdsjfls whatever they call it, that is super quick, will absolutely embarrass the Lexus and is quicker than 2018 Mustang too, also handles nicely, the downsides on the Alfa being reliability and residuals as value wise they are getting hammered but at 50k second hand with 2yr warranty are worth considering.
There is no one real perfect car, Ford has the engine, reliability and value, Alfa has the handling, Lexus has the interior and rarity.
For me the F-Type was the car never considered but it won me over, admittedly I had to go used to get the F-Type I want (SVR) but at the same time I've saved myself a huge chunk of depreciation by doing so (40-50k) by getting one in quite a desirable specification for 80k and I can tell you its a car that can play all the cards, supercar, GT, sports car, it is a brilliant thing and even better it is British and it is nice to support the British car industry which definitely seems to be on the up with what Jaguar and Mclaren are doing.
