My local Porsche specialist uses an X Type. Could be worse I suppose?Normally the case with independent garages as far as I’m aware? Last one I got was an X type of a similar age.
aye! one of the must have mods in my opinion.Always liked ducks on the MX5.
Yup and solved design flaw of upper plenum that got corrected later on.To stop heat transferring from the head to the plenum, thus reducing intake air temperature?
Well you are a funny looking fellaTbh I was just grateful for have anything at all instead of the usual “Yes, I can see you’re booking in a 400BHP RWD car but you’re far too young for us to be able to trust you with our Nissan Micra for a couple of days”![]()
ye for 100 bucks delivered and 1.5 hour job initThat is impressive.![]()
Way more than that, it changes plenum volume and runner lengths.Runner lengths can have a noticeable affect on the torque curve (You generally sacrifice some low down torque for an increase at higher RPMTo stop heat transferring from the head to the plenum, thus reducing intake air temperature?
I'm not even sure I understand how a plenum works...
In my world the air goes in through the throttle body into the intake manifold and into the cylinders. What does the plenum do?
Plenum and inlet manifold are two different names for the same thing
Ye if im bothered/bored ill buy used lower plenum and do porting/matching on it. Seen people getting extra horsea there. Was thinking about grabbing kinetix upper one if i ould get my hands on used one for looks more than gains haha.Way more than that, it changes plenum volume and runner lengths.Runner lengths can have a noticeable affect on the torque curve (You generally sacrifice some low down torque for an increase at higher RPM
