From what I've read, the updated 15x is actually louder than the old one. Not sure how much that would bother me...Yeah just watched that coincidentally.
What concerns me are some comments made by others about the cooling.
Wasn't aware of the new MSI offering in the MSI GS65
That apparently has much better cooling (more fans and heat pipes)
I was put off by the previous MSI offering - the MSI GS63 - because of the potentially low build quality, and small battery.
Then discovered the Gigabyte Aero last year, which I wasn't even aware of.
But the MSI GS63's battery is larger than before, albeit not as large as the Gigabyte Aero, and it looks decent.
Hi @Atom80 - very useful to see a Gigabyte Rep posting on forums! I've had a DELL XPS 9560 at work for the last year but will be moving to Australia in May. I had originally planned to get the new XPS 9570 before someone brought the Aero 15X to my attention and I realised it blew the DELL out of the water with its specs. The 1070 GPU vs the 1050Ti is a massive thing because I'll no longer have a desktop and need a laptop on which I can play games and also edit 4K footage etc.
Literally the only thing giving me concern is this; what is Gigabyte's policy around the international warranty? I'll be buying the laptop through Overclockers but will then be moving to Australia. OC Sales Rep seemed to think that if I needed a repair in the warranty period - I would have to send it back to the UK at my own expense and then pay for it to get sent back to Australia. Given there is a Gigabyte Service Centre in Australia, would I just be able to send it to them if it needed repaired?
Thanks in advance for any help as I'm practically hovering over the Add To Basket option![]()
Hi zaxbysauce - sorry for the delay - we will feed this straight into our R&D contacts and see what we can find out for you. Taiwan is on public holiday until Monday, so please give us a few days to come back to you.
Regards,
Gigabyte UK NB Team
@Atom80 I have a question about my 15x that I've been crawling the internet for since I got it several months ago. Can the model that does not come with a RAID array pre-configured have an array made later? I am a systems engineer with a dozen years of industry experience and I still can't quite figure this out. I have also called Gigabyte Tech Support and was told the engineering team would be looking into my issue and get back to me but that was over 2 months ago. I have 2 1tb NVMe drives installed, I flip the BIOS over to Intel RST, but as soon as I do the BIOS only sees 1 NVMe drive and RST manager in Windows shows nothing at all under storage. However, both drives are seen normally by Windows and perform perfectly fine as two separate entities when the BIOS is set to either AHCI or Intel RST Premium. I just do not like managing two separate storage pools and would much prefer one large 2tb space instead of two 1tb spaces. Any help would be much appreciated and thanks in advance.
Hi @Mark Keiller - Sorry for the confusion with the information provided to you. To confirm, buying from OCUK, and then travelling to Australia wont impact on your warranty support. The Warranty is International, and yes because there is a Service Centre in Australia, you would be able to access this under your warranty.
Hope that clarifies the situation and gives your the assurances you need.
Best Regards,
Gigabyte UK NB Team
Thanks @Atom80I noticed an Australian retailer that mentions Gigabyte offer a pick up and return service for any repairs under warranty. Would I also be entitled to this if I had bought the laptop in the UK?
I could just order the laptop from them and save a few hundred £ because of the exchange rate (would just have it delivered to my partner over there in Sydney), but I'm not moving until May 19th and could really use the laptop in advance of going over there.
@Atom80 it’s the Aero 15X (4K) model I’m wanting to order. That would be perfect if the warranty includes ‘collect and return’ to the local Gigabyte Service Centre - I’ve had lots of differing information about this so would appreciate 100% clarification that I would be covered in Australia for that service even if I had bought the laptop in the UK.
I logged a ticket on the Gigabyte support center asking the same thing but they just said:
“For AERO 15X (i7-8750H), GIGABYTE Global service will be 1 year from the date of purchase. Users will have to register the product online by filling in the online registration form. We will not provide global warranty if users do not register the product online completely. Please be aware.”
Thanks for your help!
@Atom80 - retailer in Australia (affordablelaptops.com.au) said:
“You may need to clarify this through Gigabyte but as far as I am aware, if you purchase the laptop in Australia with a receipt for warranty then the pickup and return service is for that country only.
It does have international warranty but you have to take it in to that service centre if you are overseas from the country that you purchased the laptop from.”
Hi @Atom80,
I appreciate the quick response and elevation to the engineering team, however, there seems to be a disconnect between what is expected to occur in the current BIOS vs what I am seeing locally. I have tried all 3 BIOS versions currently available and none of them display any ability to create a RAID array at the BIOS level. I have attached screenshots of all the relevant BIOS screens here. Let me know if you need anything further and again I really appreciate the help. Standard Gigabyte tech support has been very limited help so far. As you can see below, there is no option to create, modify, or do anything with a RAID array. I have also tabbed out of the splash screen on boot and verified there are no prompts for array creation there. Thanks.
https://i.imgur.com/pTMc27p.jpg
https://i.imgur.com/tXfRLFR.jpg
https://i.imgur.com/ptXNkBl.jpg
https://i.imgur.com/0wFtqMh.jpg
That's great @Atom80 thank you for taking the time to check and clarify!
More than happy to proceed with ordering the laptop through OCUK now - did you guys have a better idea of availability date?
The ticket was logged through the Gigabyte eSupport site, and they actually just replied echoing what you said as well:
"We are sorry that after double checking with relevant parties, AERO 15 (I7-8750H) has 2 years globe warranty. If after-sales service needed in Australia, you may please contact directly with our Australia service center as the information below for the warranty service.
GIGABYTE Australia Branch
Address: Unit 1, 19-23 Clarinda Road, Oakleigh South, VIC 3167, Australia
TEL: 61-3-8561-6288
Note:
1. Pick Up and Return Service for notebook/ netbook covered by warranty in Australia is provided. Please contact GIGABYTE Australia Branch for details.
2. Please do NOT take any action (send out the product or visit our service center directly) before contact our service center. If you do not contact our service center to get further information, our staff will not be able to proceed the case. We appreciate your cooperation.
3. Before sending the laptop for repairing, make sure you have backup files in advance."
Hi Gigabyte Rep (atom80). - Whilst you are onto this particular aspect (and can be so easily reached about this same matter), i happened to notice that another major UK retailer (s**n, sorry I cannot say who they are due to the OCUK forum rules). Well they also have a misprint as such. And are also not correctly advertising the RTB period of the warranty. It is showing over there as 14 month (instead of the full 24 months). So you might also want to let them know over there too. To ask them to make a similar type correction. You have to click the 'Warranty' tab on their aero15x product page to see it. Have a nice day.
Hi - yes there has been a few internal emails, so I thought you might have had replies from different parts of our organization - should now be consistent and also it brought to light some text on web-sites that has now also been updated - so thanks for bringing it to our attention.
Regarding ETA for the UHD version - it should be here in the next couple of weeks, but if it doesn't tie in with your date to travel to Australia, you will obviously be able to purchase over there.
Thanks again,
Regards,
Gigabyte UK NB Team
Hi @Atom80,
