Deleted member 651465
Yes, I have a HG612.Thanks a lot @EVH
Do you have experience of the HG612? I looked last night and couldn't find any settings to control it's IP address.
Also you mention HG612 to poe switch. Does it not need connecting to the WAN socket of the USG and then a cable from the USG to the switch? I can save a cable if that's not the case.
Sorry, I meant to say hg612 > usg > Poe switch. Rushing and on the phone!
The lan ip setting is weirdly hard to find, but I’ll check later and update you to where it is. From memory it’s under basic > lan ip.
Connect Lan1 on HG612 to WAN1 on USG and configure the pppoe connection within unifi.if you want to be able to log in to the webpage of the HG612 then you need to connect a cable from LAN 2 on the HG612 to the Poe switch as lan 1 is used for WAN*
*if you want simple just connect your pc to lan2 on the hg612 using a manual ip for the pc that way it’s a “direct” connection.
