- 18 May 2010
- London
My "8 Pack Edition" 3200 RAM arrived earlier today. Works fine in my Asus X470 Prime Pro using DOCP, 100% stable.
You say that. But it hasn't been very long has it.
You say that. But it hasn't been very long has it.![]()
Have a mooch here https://forums.overclockers.co.uk/posts/31764459/
Looking at picking up some of the 3200MHz RAM while it is on offer https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
Does anyone know how tall the RAM is? As I'll be fitting it along with a NH-D15 cooler but it limits the usable height of RAM. From a thread on LTT forum, it looks like the cooler allows up to 37mm clearance if using 2 fans.
I've had this ram 3 weeks and still having found stability at DOCP.
I've tried everything.
I can get it to pass HCI 400% but then freezing and crashing games.
It's either the ram or the mobo.
Same issues with both a 1700 and a 2700x.
Well people havce been saying to RMA that ram for weeks, so not quite tried everything yet![]()
I had an RMA open with Overclockers. But they mentioned they would test the ram and if they found it not faulty well then I guess they wouldn't replace it.
That's the issue. I test it using HCI and it passes (at least 400%) but then when I play games. Freeze and games crash.
I changed my windows power profile last night to high performance. I managed to play about 1hr with no issues so lets see.
@8 Pack i was wandering sir if you had tried to get this ram past 3200 mark on gigabyte gaming 5 x270 and ryzen 1600 at all ? do you think its possible at all ?
or if any off the other guys has tried this and been succesfull ?
3200 on amd imc is not a given you know.... Intel sure but some amd imc are just junk.
