Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
The car feels much much better now with new pads on them, now I’m thinking getting the polestar map.
Take it to shark performance. Ben wardle knows a thing or two about Volvo's.
I would but I want to keep everything "stock", and the Polestar one is the official one.
Ah ok. What figures does the polestar give?
Officially it takes it from 227 to 250, but people who has done it have dyno it to around 265-270.
That's a nice increase @Phemo , what car?
Stripped down my rear brakes to find one side the pads had been at an angle and been stuck in the carrier. Wondered why when hot it felt like I had a stuck caliper.
Got new discs and pads however the new pads simply do not fit in the carrier. This can be common, it's just the ears that seem too big. I've bought some files to make sure the carrier is as smooth and flat as it should be so the fitting clip sits well but I feel I might have to attack the ears too. So long as it's tight but can move I should be OK right? I don't wanna take too much off and have noisy brakes.
Some ***** knocked and scuffed my mirror because he was too impatient to wait behind a row of parked cars. *******.
Over the past couple weeks:
Oil change and filter
Air and cabin filters
Coolant change
Diff oil change
New rear calipers and mounts, plus a brake hose
New front caliper mounts
New pads
Brake fluid flush
Bulb upgrades
Headlight sanding, polishing and clearcoating
Passenger footwell panel repair
Interior and exterior washed
Alloys ordered
Next is a better set of tyres once these treads wear, previous lady owner pottered about on mismatched bottom barrel tyres, then I'm done for a while! Front caliper will likely need rebuilding too, noticed the piston seal lifting.
geez have you bought one of acme's old bangers ?
