- 11 Mar 2013
If speculation is to be believed, then another way to phrase that is "Waiting for Navi"I'll give up on PC gaming and save my money so I can join the console peasants when the PS5 is released in another years time!
Excited to see what comes out but if the launch price really is $700 plus the miners tax I'll give up on PC gaming and save my money so I can join the console peasants when the PS5 is released in another years time!
Surprised to see the rumours claim it will have 16gb of RAM. I didn't think that would increase over the current 8gb this generation.
Those famous two little words.According to the same entry, the memory in question will be the GDDR6 variant with up to 16 GB worth of DRAM.
Those famous two little words.![]()
Certainly not on a gamers graphics cards, maybe on the professional version though.
4K is what everyone's eyeing, though, just because consoles are listed as having it, even if they don't have a full implementation (low framerate cap or upscaling). If the new GPUs don't run 4K flawlessly because NVIDIA has decided to give us as little an upgrade as possible, we are going to have a good reason to be upset as PC enthusiasts.I'd be very surprised if we get 16GB (of expensive GDDR6), 8GB is still plenty for other than 4k. Maybe the next Ti will have it, just can't see the normal line having it yet.
NVIDIA definitely are capable of launching the next flagship with 16GB as standard, but because of the serious problem right now with RAM prices, I think it's extremely unlikely they will do that until the next Titan/Ti series cards.
A possibility is that they could launch two variations with the 16GB costing about $100-200 more than the 8GB (I know, steep right).
Next Titan may have 16gb but it would be very unlikely that cards lower down the range will as this would make it hard to justify paying the extra for the Titan.
Also I have not seen any game use more than 11gb of memory @2160p with all the settings maxed so NVidia would be wasting money on memory for a mainstream card if they went beyond 12gb.
I suspect the new 1180 or whatever they are going to call it will pack 3840 cores and a 384 bit bus, this matches up quite well with 12gb of GDDR memory. Also using this spec and 12nm means the card will be about 10% to 15% faster than a Pascal Titan.
I think a 384bit bus on a non-ti model is unlikey, as they would have to give the ti/titian a 512bit bus to separate it, in both cases it would drive up die size and cost and power abit as well (not to much though)
256bit with GDDR6 and any other memory bandwith saving tech will be more than enough, If AMD was realy screwing/pressuring them then maybe a 384/512bit bus would be used if it gave meaningful extra performance
That's it. They're done. Pascal gaming until the end of time!10: Gaming Perfected
Haven't Sony stated no new hardware for 3 years? If so, good luck with that wait!!
Where did you hear or read that?
I think Sony CEO said we mightn’t see PS5 till 2021 awhile back.
