- 14 Oct 2007
- newcastle
It sounds like both YouTube streams were interlaced and now tv is progressive
That should be the correct way to do it, maybe refer back to your amp’s manual to check you have it connected the right port? I’m sure I read that some amps need to be connected to the output as it’s ‘audio Return channel’ so it’s backwards... might have been rubbish, but have never tried it myself!
On a side note, I picked up this beauty over the weekend and I’m really pleased. Watched the F1 in UHD on the sports mode and it looked great... just make sure you turn off the true motion setting, it’s awful!
Now, to pack the TV away before I move. Must find a way to re cover and repackage the set without scratching it!!
Unfortunately it looks like the amp will only see the ARC from the TV when the TV has CEC enabled.
Unfortunately it looks like the amp will only see the ARC from the TV when the TV has CEC enabled. I don't want CEC enabled as I control the TV and amp via a harmony remote. Now the remote is a bit useless... pain in the bum.
That is correct, ARC is part of the CEC spec and will only work with CEC, you're main option is to use Optical out from the TV.
Hey folks, tempted to get a B7 or maybe C7 as it seems to be the best reasonably priced OLED going at the mo!
Where have people seen it the cheapest? Everywhere seems to be doing the B7 for around £1399 at most places. I’m going to have a look at one later to see what it’s like in person before making the final decision.
Thanks for the RS code.
Has anyone had any of the issues with tinting, banding or burn in? Seems to be a fair amount of talk about it online? Is it just the vocal few? It’s the only thing that gives me pause![]()
where are the brightness / contrast controls? are they hidden or something?
watched the game last night and it's just way too bright and the eye strain mode looks horrendous.
