I would take out the glow-plug and put some wd-40 in there and leave it for a while - the longer the better. Try it again on the starter box, without the glow plug, hopefully it'll free up.
ok - thanks
Long time bump for this thread!
Got myself a 2nd hand Losi 8ight-t 2.0 RC Nitro Truggy - not been run for a while but overall in excellent condition.
Comes with everything I need and despite having a reasonable background with drones/engines etc - I can't get the thing started on the starter box. Starter box is aligned well but the blue flywheel on the bottom of the engine/chassis just won't turn over at all. Starter box wheel spins up but just won't turn the flywheel on the Truggy. Seems very solid.
Would heating it with hairdryer work?
Sounds like the engine maybe stuck top dead centre if the engine has not been broken In the piston and sleeve will still have a mechanical pinch
My advice would be remove the engine from the car then remove the head off the engine youl want a 2.5mm hex driver and and then try turning the flywheel and try lift the the sleeve out slightly to free it off
Also I don't reccomend wd40 youl be better off with 3 in 1 oil
When you put it back together try getting as much heat on the engine before starting it to expand the sleeve and run it rich
Did you prime the engine? Before you put your igniter over the plug put your thumb over the exhaust and run on the box so the engine sucks up some fuel in the carb
I'm at my wits end with my RC car, suddenly the throttle control has stopped working but the steering is fine. If I swap the steering to channel 2 on the receiver then the throttle works using the steering on the transmitter but the throttle won't control the steering. I've already stupidly replaced the ESC and motor thinking that was the problem (before I tried swapping channels). What could it be? Knackered transmitter possibly?
Sounds like the transmitter is stuffed.
Be a relief if it is, even though it's new it's a cheapo hobbyking transmitter so I'll go at it with a soldering iron. Cheers.
Before buying a new transmitter just double check the receiver connections and make sure they are in channel 1 and 2 and not battery and channel 3 etc.....
If the above is all good then I'd say deffo transmitter.
Anyone know any websites for cheap RC cars for a newbie who doesn't want to spend a fortune just for it to end up in the cupboard?
What you after on road or off road nitro or electric?
This arrived today.
How much was that and where from please?
Tamiya Bruiser clone.
