So a few pages back when I said that
You have all jumped to defend Vega, even though you now admit that the default settings are not good. the bottom line is that Vega is power hungry and it was late to the market, or do you want to argue that point as well.
You want to argue the power consumption point by using a 1080Ti extreme, vs the card you have after you have tweaked it, how is that a fair comparison.
Well that is one opinion, another would be.
Well AMD have prettier driver interface, a comparable variable refresh rate experience, very similar image quality, but saying all that they are dearer, consume more power and were much latter into the market.
Hold on a bit on the power consumption front. I had until yesterday a GTX1080Ti Xtreme, with no manual overclock just the normal boost and was consuming 70W more than the V64 Nitro+ I have today. Dont take the feeble FE power consumption to make a case for it. Take the factory overclocked versions which some are bordering to the old mighty 295X2 in that front.
Point out these loads of people.
They might not be all great overclockers, but, they all can be tweaked to use less power and perform better with a few simple steps because the default settings are rubbish.
