- 23 Mar 2011
Be really cool if they sent them to you, officially printed etc. Make for a good collectible for the game
Expensive week. I played the demo for both of them and questioned which one to get. Browsed the store and thought **** it let's get both. My willpower is weak.
Hope you got Captain Toad too!
Didn't actually defend Nintendo there. I just called out what I saw. You being a boring attention seeking ****.
Anyone who plays mostly in handheld mode, i would definitely recommend getting the Mumba case off amazon. Adds a little bit of bulk round the joy-con area so it's nicer to hold for longer periods of time (my hands go stiff holding the switch with no case in the matter of 20 mins or so). But it also holds it all together and makes it feel like a much more solid unit , as I thought after a while the joy cons do loosen. Also protected mine from a drop thank the Lord haha
https://www.amazon.co.uk/Mumba-Nint...witch+case&dpPl=1&dpID=51F8tsrO2xL&ref=plSrch
Been playing mostly fortnite recently getting into it, presently surprised how well it runs , thought it would be a direct port of the mobile game bit it's actually a lot closer to the consoles which makes it brilliant to play in handheld
Going to add one of these to my next order as I already have the Orzly carry case, looks the business and well reviewed.
https://www.amazon.co.uk/ORZLY®-Comfort-Grip-Nintendo-Switch/dp/B077V57CVV
That looks really nice. A lot more elegant that some that I have seen. My only slight reservation would be having to remove it every time I dock it - for me, that would be every single day.
(I'll probably end up buying one next week...)Get a USB-C extension cable and just plug that in when you want to play on the TV. The dock heats up the Switch rather than cooling it so you won't have any problems there.
Got the Prime Day deal for the Switch with Odyssey and a Pro Controller for £330...do I pull the trigger?!
Edit: Bought it, then immediately cancelled the order...I can afford it, but have three forthcoming holidays to pay for and am trying to buy a house. Sensible-head won this round(I'll probably end up buying one next week...)
