Blobs are bigger than ever as they generate news articles so CCP encourages blobs. It's still the only MMO worth playing though that has got some nice updates.
hows everyone finding the latest update?
Ex Beta player - left in 2013 - wondering if its worth another shot. Used to play in 0.0 sec a lot. but blob warfare doesnt interest me in the slightest.
No reason not to recover the old accounts, starting fresh will just put you in a worse position than you were when you left last time.
Yes, exactly that.
Ok thanks, will have to look see how to put them back on then
My current PC broadly consists of:
Dell 2560x1440 TFT
Intel i5 3570K @ 3.4GHz
16GB DDR3 RAM
nVidia GTX 1070
I wish to run 6-10 clients at the same time at 2560x1440 (or windowed 1920 x 1080 would be acceptable) and can’t at the moment without lag when switching between each client instance and unacceptable performance. I don’t want to have to use minimum graphics settings either.
What do I need to change with current hardware to do what I want?
Ta.
I would check with a resource monitor to find the bottleneck before spending any cash. Check CPU, GPU, RAM usage.Thanks Rroff.
Changing RAM is fine, but currently using 4 x 4GB sticks, so will have to swap it all for 4 x 8GB sticks rather than just add another 16GB. Meh![]()
Haven't watched it but R&Ks put up a new video
EDIT: Looks like its mostly based around the Serenity server though.
EDIT2: Not that great mostly a slide show of events on Serenity over the last couple of years.
Do you play Eve though?Start watching it and fall asleep while i was at the same time full of rage due to some muppets in World of Tanks.
Most boring video ever.
