- 25 Nov 2005
Pointless joining facebook group when your account gets locked every time you go to ask a question and then they ask for a photo which they can **** right off because I'm not giving them one
As it's going to be my first 3D printer, outside of a spool of filament any essentials I should buy?
depending on the setup some tape for the bed (I use blue decorator's stuff) and some Pritt Stick or the UHU equivalent for bed adhesion can be handy along with a thin scraper of some kind for removing the model from the bed (I'm not sure what the bed setup is on the Ender 3).The right tools for cleaning the extrude/hot end if it gets jammed are handy to have especially if like mine it used a very specific size of hex key thingy that common sets of them skipped overdepending on the setup some tape for the bed (I use blue decorator's stuff) and some Pritt Stick or the UHU equivalent for bed adhesion can be handy along with a thin scraper of some kind for removing the model from the bed (I'm not sure what the bed setup is on the Ender 3).
Insette extra hold, 1.99 or 1.49 cant remember, for huge can @homebargainsIt's a Build Tak clone, a lot of people seem to be very happy with a sheet of glass and Hair Spray
Going to order a Creality Ender 3 in the next few days.
A BLTouch auto level (arduino and some dupont connectors as well to flash bootloader) and some borosilicate glass otherwise you're going to be very frustrated with levelling the bed every single time you wish to print especially on long prints because the bed you get goes to **** after a few days of printing, probably some spare nozzles too
Hairspray too if you want to print more than PLA I've found this to be cheap for 400ml and decent for sticking PetG https://smile.amazon.co.uk/gp/product/B001GFBQO2/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Is it difficult to install the BLtouch? It does seem really handy. How does it actually work? Do you just level your bed once, and then it fine tunes by actually working around any wonkiness while it prints?
It's difficult if you're not technical but it should be easy enough for people who frequent an overclocking forum
I bought the Chinese version as it's $14 and basically the same
dont you loose microsd functionality?
