Riding indoors this time of year without a fan?!I definitely need to put a fan in there!
You're probably best looking at second hand Flow/Vortex smart - https://www.dcrainmaker.com/2017/10/annual-trainer-recommendations.htmlBudget is low, would prefer ~£50, but maybe upto £100
Don't forget to factor in the monthly cost of Zwift/TR/Sufferfest along with additional things you may need - trainer tyre (if you don't have any old tyres), spare wheel (if swapping bike from trainer to outside use), USB ANT+ adaptor, TV stand, a fan or two, bike thong, headphones etc etc etc.
I can recommend the Vortex, I've owned one for several years and as a 'starting' smart trainer it's perfect. If your budget is an absolute and you need some other bits then the Flow Smart is a good cheaper alternative but only stores sell them, they're not generally sold online. Halfords & Decathlon spring to mind, not sure if Evans' stock them. Could be worth checking if your Evans' vouchers can be spent alongside other discounts, I used my British Cycling discount to get 10% off from Chain Reaction, for the £25 yearly BC membership getting 10% off a £630 trainer was well worth it!
My trainer recommendations are currently -
Low range: Flow/Vortex maybe KICKR Snap.
Mid range: Elite Direto (you get more trainer than going for the Flux like I did).
Mid/high: Refirb KICKR. KICKR CORE
High: Neo.
Ah okay
Lots of reading to do then, was after something reasonably simple tbh
I was probably over complicating it, apologies if so. I was thinking you where after a Smart trainer so you could use more accurately with Zwift/TR/etc.Ah okay
Just get a basic mag trainer for £50~ It'll still work with apps but won't be controllable in the same regard. For what you intend to use it for though it really doesn't matter.
Don't bother with a trainer tyre or any of that ****, just make sure you have the specific rear wheel skewer, towel/mat and a fan and you'll be fine.
It's a slippery slope as there's so many features!I like the idea of being able to do that and haven't read up on it at all,so it was a bit of an open question.
27.5 or 29"? Some mag's do, I used to run a 26" hybrid on a Kurt Kinetic Road Machine II. I also ran a 700C road bike on it afterwards, the resistance unit had different fittings where it would attach to the frame to allow the different tyre circumferences. I'm fairly sure the Tacx Vortex Smart I replaced it with had the same.We only have mountain type bikes, do most mags accomode those tyres?
Tacx Flux bonkers cheap atm - £460 with BC discount.
Or is it worth paying the extra to get a Direto for £580?
Have the Flux niggles gone away now? I have no patience for stuff that doesn't work.
