Keep the oil level on max when on track, see how it goes, beauty of these Clio's there is loads of engines for sale, running ones, £300 so you break it, well its cheap to fix.
Just ordered brand new Renault 172 cup dampers all round including top mounts, £185, it simply makes sense to do so as at that price its a steal for genuine items and I am sure the original dampers after 15yr/50k miles are no longer at their best. Now just trying to find some original springs ideally to put on them, or maybe just grab cooksport options just don't like idea of lowering it really.
Go for Eibach Pro Kit. Pretty much no drop (10mm ish) and progressive, if anything they ride better than OEM.
Posted from Germany, takes about a week - https://www.autodoc.co.uk/spares-search?keyword=+ E10-75-001-02-22
Did you get the modified spacers with the genuine top mounts? They tend to clunk without them.
https://www.renaultpartsdirect.co.uk/parts/renault-clio-range/clio-172-182-shock-mount-spacer-nut/
