Highlights
This is GeForce Hot Fix driver version 398.98 that addresses the following:
- Resolved stability issue with latest drivers when running LA Noire VR
 - Resolved a stutter issue for some configurations in the Call of Duty Black Ops 4 Beta
My overlay (alt-z) doesn't work anymore, so I can't record. Is there another way of doing it or a complete reinstall needed?
I spent hours trying to fix this over the last few days. Uninstalled everything completely, and installed an earlier verion. The share option (so I can record my games) worked for a few seconds before it updated on its own. And then it broke again.
In the end I uninstalled via DDU, installed an older verion and blocked everything in Eset firewall so it cant update. I dont understand why Nvidia and even other companies force updates on us all the time. If you dont want to update then we should be given the choice!
Even after blocking, GeForce Experience is constantly trying to get 'outside'. Over 1500 attempts in the last couple of days
	Windows 10x64 and 1080Ti.
for some reason the 398.xx series of drivers causes my PC to either randomly reboot, rare but has happened, or do a full screen type refresh in Windows, as though you have stopped Explorer and started it again.
If it did reboot the error reported in the dump file would link to nvlddmkm.sys.
Prior to that I have been using the 391.31 drivers with zero issues, so I have gone back to those. Hopefully all will be well now.
Interesting. I've been getting random reboots in the middle of games and was blaming it on mobo or psu. Eliminated the PSU and put it down to mobo and temps. Eliminated temps and now I've been blaming it on power surges from power cuts. I'm on 398.11, did this happen with 398.82 for you?
Filename : nvlddmkm.sys
Address In Stack : nvlddmkm.sys+1f5401
From Address : fffff805`ac570000
To Address : fffff805`ad62d000
Time Stamp : 0x5b6cf3ec
Time String : 10/08/2018 3:09:48 AM
Product Name :
File Description :
File Version :
Company :
Full Path :
Ok I'm talking about instant hard reset with no dumps. Think we're getting different effects.Yes it did. It took me a while to pin point it to the 398.xx release and a longer testing of the 391.31 drivers is needed to confirm what I now suspect. This is the error that I was getting after reading the dump files from a reboot...
The screen type refresh within Windows happened more often than a reboot for me, on an other wise stable system prior to the driver update.
As noted the 391.31 drivers were great, not sure why I bothered to update them - note to self not to if all is well...!!!!
Everything removed except:
- Driver itself
 - PhysX
 - HD Audio
For those looking for an install package without the bloatware / spyware
I've done a few installs of stuff like this, mostly pulling it apart myself, for people lately where official release = crashes and/or driver TDRs and/or stutter installing the same driver with a bunch of the extra services, etc. removed = no problems at all. Its a bit annoying and I expect nVidia will start hardwiring some of this stuff to prevent people unpacking the driver like this down the line![]()
Game Ready
Provides the optimal gaming experience for Battlefield V Open Beta, F1 2018, Immortal: Unchained, Pro Evolution Soccer 2019, Strange Brigade, and Switchblade
Clean version https://forums.guru3d.com/threads/399-07-whql-clean-version.421390/
Clean version of 399.07 x64 drivers for Win 10, 8.1, 8, 7 x64.
- Driver itself
 - PhysX
 - HD Audio
Will these have the Pascal downgrade V1.0 in?
Or will they be in the first Turing driver?
Pascal downgrade?
