- 9 Apr 2012
That notch is massive, it at least 50% bigger than the Oneplus 6 notch.
Why does it even have a notch. When will these companies understand Apple did it for practical reasons not for a design statement
**** the notch, look at that chin...That notch is massive, it at least 50% bigger than the Oneplus 6 notch.
I don't think it's that. He mentioned in his video his current Pixel 2 had a DP installed so he got a second stock Pixel 2 and installed the same apps and that slowed down as well.Orrrrrrrrr the continuous poorly optimised software updates?
I am using a Samsung S8 which has 4gb of RAM. And it's plenty snappy.
They didn't in the past. The Nexus 5,6,6P and pixel 1 were very very good.
This whole notch thing is just embarrassing though really... Really thought Google had a bit more self esteem!
It is a combination of crap 'beta android software and the ram yes.MKBHD released a video about his daily driver and he's moved over to the OnePlus 6, from the Pixel 2, because he found the Pixel 2 quite laggy in comparison. That's got to be RAM related tbh.
Maybe, maybe not. But look at the image.I personally think you're reaching for things if you say the chin is too big. It's the same as the Pixel 2 XL, which is just about right to me. Any more and you're basically looking at edge to edge. Yes, others have smaller, or basically no chin, but that doesn't mean this is 'big'. It's about the same as the Huewai P20 Pro for example. Given it has stereo front facing speakers, I think it's fine.
Heres a link to the full res image - https://pbs.twimg.com/media/DkuesyXUYAAFmKo.jpg:orig
Look at the amount of space between the speaker and the pill.
More pics of it in the wild.
https://9to5google.com/2018/08/20/google-pixel-3-xl-leak-front-back-case/
Haha, good. When did that happen?
