Hi all,
I need some help discussing Which Chip to go for my new build after researching The 7900X is looking better in many use cases. Gaming/Visual Studio Work better with Clock/Core count of the 7900x
Current build is 1800x 16GB RAM
Use Cases: Gaming,Programming,Multitasking,Light room,Heavy Browsing usage
7900X
Pros
Better 0.1 lows in Games
Better In games Generally.
Consistent performance in any use (no switching between NUMA/UMA and such)
Better Memory Support (Generally)
Cons
6 cores less 12 threads less
Less PCI-E
Notes:
Not much difference in cost
2950X
Pro
More cores more/Threads
More PCI-E Lanes if needed
Better in multitasking
Cons
Not as good at memory support (higher clock)
Compiling Not as fine tuned as compared to Intel,
Compling not making use of the 6 extra cores.
anything you think you can add?
7900X
Pros
Cons
Less PCI-E
Notes:
2950X
Pro
Cons
Ryzen isn't even the question. he's asking about Threadripper.
