I've been doing exactly this for 25 years, no problems yet!
That's how my dad taught me to do it, and he's never had a problem either
+1 usually put some on the hub face too so they do not become galvanically corrode/joined.Copper slip. So they come undone again
As above, always done that, and most people I know do that too. Never heard of any issues as a result. Garages/tyre shops etc never do them to a specified torque either.
Kwik fit and national myabe bad places then, but they are always torqued such that, apart from needing extreme force, and fearing bm iron might round the bolts, I would be concerned about car rolling off the jack if I did have a puncture in the wild, where I might forget to protect that, with non-space saver spare, in the cold of the moment.All the tyre places I have used recently have torqued the wheels up correctly, so may be you just need to use a better place
... or call the AA ingominiously, more buisness for them.
Have never spec'd/purchased a long brace .. do halfords pro have (a non cream-cheese) one ?
good point - I indeed do that - so, just a comment about instability of inbuilt jacks when lifting wheel off of hubGenerally speaking you should crack off wheel bolts before you jack the car - this is to avoid that specific problem. Not undo them completely, just get them going. Saves a world of pain.
@Acme you keeping the corolla now? Seems like the longest you have kept your cars in a while![]()
