- 9 Nov 2009
- Planet Earth
its the other way round, the image with DLSS has a lot more detail in the textures that gets lost with TAA
https://bit-tech.net/reviews/tech/g...-ti-and-rtx-2080-founders-edition-reviews/11/
In this instance, DLSS, despite being advertised as only having similar quality to TAA, was always the better method for image quality. You do have to look for the finer details, such as complicated foliage in the background, the creases of clothing, or hair, but in doing so you invariably find a better image with DLSS than with TAA (also confirmed by a few quick blind tests with nearby staff members). For example, sharpness would often be improved over TAA, which could sometimes suffer from a slight blur effect in comparison, and there were fewer artefacts on the DLSS side too. Occasionally, edges looked a touch jaggier with DLSS, but it remained the clear winner overall. There are some examples below: In each pair, the top images are captured using TAA and the bottom images with DLSS. We suggest opening them in different tabs or downloading and saving them, then zooming in to spot differences in the areas we mentioned.
I get what you are saying now,but then if you look at what they have posted it is:
TAA(top)
https://bit-tech.net/media/image/2018/9/b63d6405-e0ad-446e-9d5c-4946e56b994b.png
DLSS(bottom)
https://bit-tech.net/media/image/2018/9/fd9be391-c1e6-48ca-aa16-edd9de58d4e7.png
The description says one thing,but the order of the images shows a different thing. The top image has worse edges,and better detail and the bottom has better edges and worse details.
I might send an e-mail and ask them if they mixed it up.
