- 6 Feb 2010
AMD don't really need answering to RTX 2000 series in the specific features given current timing the features ain't going to take-off at the speed of light. As long as they are prepare to answer to the RTX 3000 series, that would be enough. Like Nvidia didn't answer to AMD's Async Compute on Maxwell and only answered to it after they brought out Pascal it didn't hurt them one bit in the real-world practical applications in the gaming environment.If AMD don;t have an answer to RTX then it will probably be their downfall, much like 3DFX coudln't respond to Nvidia's hardware TnL in the original Gerforce. Whther AMD have time in the short term is unknown but at least AMD will have to be gearing uop for a new race to have RTX capable gaming cards.
But anyway, from what we have heard about Navi it wont be competing with the 1080ti, but more like the 1080 and below, which is exactly the market segment Nvidia will be replacing with 7nm GPUs at the same time.
It's not as if the RTX 2080ti is going to deliver 60fps at 1440p with Ray-tracing on, as all the leaks so far seem to points to that it cannot even do a solid 60fps at 1080p with Ray-tracing switch on. If a game can deliver that with Ray-tracing enabled, the chance are the Ray-tracing quality is either really dumb-down to close to non-existence, and the particular game is nothing more than just ticking the checkbox for Ray-tracing.
As it's stand (if all the current available demonstration was accurate) enabling Ray-tracing people have to trade-off huge amount frame rate or dial-back their resolution to lower resolution for the sake of using Ray-tracing, in that context it hurt more than the small fortunate being spent on the card.
