Core 9000 series
19 Feb 2011
What's the lowest spec I can get away with in this setup:
- 9900k OC on air only
-16GB RAM
- 1TB SSD (already have it)
- need 10+ usb ports. max is usb 3.0. Mainly for simrig components and VR
- 2080ti
- Onboard audio. Nothing critical just VR headband audio and basic youtube etc.
I don't care for RGB or a bunch of fluff that I'll never use.
Spends top end money on CPU, GPU, SSD, VR kit but skimps on Motherboard.... Seems legit ;)
15 Jun 2005
Edinburgh
Is the 9900k expected to be a power hungry cpu? The reason I ask is that every board in the Gigabyte Z390 range linked to above has 8+4 pin cpu power connectors apart from the Z390i Aorus Pro WiFi.
Standard boards are 8-pin. Overclocking boards are 8+4 pin. Extreme overclocking (LN2) boards are 8+8.
Some of the MSI boards can deliver 540 watts to the CPU. :eek:
Man of Honour
30 Oct 2003
Essex
Great thread guys. Have been lurking for a couple of days. What do you think it will do to the second market for 8700k as was hoping to pickup some good deals.
In my opinion not a lot, they can't make enough of them to meet demand and prices have been heading upwards. The new chips will likely launch in limited numbers and be expensive, in turn this keeps the price of the second hand 8700k high along with the retail price of the 8700k artificially high. I might be wrong but for now the best time to buy an 8700k has already gone.
28 Sep 2018
Legit as they come. Doesn't mean I enjoy being wasteful:
F99iuIK
K1oOkbj
30 Aug 2018
On mobile so i don't know if it's just for me or not. But a lot of pictures on these forums show up as an image symbol sometimes or maybe always followed by IMG in square brackets.
6 Aug 2009
I think the motherboard is one of the most important components. It brings everything together, transmits the power and had a lot going on on it for the money. I've never regretted buying a decent quality board, not the most expensive but one with higher quality components.
I also suspect it makes a difference to the stability of the system along with a decent power supply. That's worth an extra £50-£100 to me just to save the hassle!
19 Feb 2011
+1 to this, if I'm buying a 9900k I'm damn well making sure i buy a mobo with the best Vrms etc.
