- 1 Dec 2015
But but everyone says you dont need a Z390 board to run a 9900K???!! well ok you dont need one, but surely the Z370 will allow you to OC a 9900k to its maximum potential right... right????
if ou've got a flagship Z370- will be fine...
still need a damn cooler on it, prime at 5ghz with a £40 air cooler soon sees it reset its self
What is the z390 chipset bringing over z370? Is it just integrated usb 3?
basically H370 in Z form - and then realising need a lot more phase and power!
honestly Z390 was on the design boards even before z370 shipped
so potentially all the solder has done is actually enabled them to cram an 8/16 into a 8700k casing
