Yes plenty.
Energenie for starters.
These.
https://www.busch-jaeger.de/en/products/product-solutions/remote-control/zigbee-light-link/
These.
https://www.gira.de/gebaeudetechnik/produkte/manuelle_lichtsteuerung/zigbee-lightlink/features.html
From what I have seen Hue look to be partnering or at least officially bringing these to the UK Q4 of this year. Which is what in waiting for.
What kit, and what happened?
Has anyone got any experience of the Osram Lightify RGB GU10 spots? My system is a mix of Hue and Ikea bulbs (Ikea for the GU10s as Hue bulbs are not bright enough). Looking at adding some RGB GU10s to my daughter's room, and the Osram ones seem good - any opinions?
Got mine today and must say they are very bright which is good as my hue bloom wasn't that bright,loving these new ones![]()
How do you find the Ikea GU10s? I've been tasked by the missus to replace the GU10s in the bathroom with ones that work with Hue, ideally RGB but she can make do with changeable white. I looked at the Hue bulbs but the white ones are still £25 a go!
Hue Sync, is there any way to make it work from an Android TV?
Love the idea just don't want to go down the HTPC route again.
I have a couple of hue bulbs, both in lamps.
I have them called
Frontlight
Backlight
I then have them also in a room called Living Room.
I also have Alexa so if I say Alexa Frontlight on or Alexa Backlight on - then the correct lamp turns on, and in reverse off works too.
I have also then connected them to my Harmony remote so can turn them on and off through the remote.
I am having an intermittent issue with Alexa not turning both lights on or off when I use Alexa turn on Living room or turn off living room.
It sometimes work and then sometimes Alexa says Living Room does not support that (or something like that).
Any ideas?
Any ideas?
