Believe me if you do any stress testing on 9900k you can't even get close to 1.45v before your at 100c. Prime 26.6, Real bench, terragen etc etc... More like 1.275v for good 24-7 temps. On 9600k you can go to 1.32v under these types of load to remain in the mid 80s.
Not by overclocker it's not even the OEM version of the 9900k is the same price as retail for some reason..I thought OEM cpu's were discounted due to lack of packaging etc
Don't forget the OEM ones have been binned and tested and didn't make the grade to be sold as pre binned clockers. So expect a dud overclocked.Retail get the game pack too. So the OEM deal remains sour.
Binned and tested by who?Don't forget the OEM ones have been binned and tested and didn't make the grade to be sold as pre binned clockers. So expect a dud overclocked.
The retailers that get them. You think a retailer that receives an open tray of CPUS won't test them and see which overclock the best? Especially if said retailer then specifically sells binned and garunteed ghzs chips for a premium??Binned and tested by who?
For our tests, we have the Intel Core i9 9900K head on with the AMD Ryzen 7 2700. They are both the top of the line in the mainstream product segment. We tried to make sure that both setups are kept as similar as possible to ensure a fair test between the two platforms.
Ah okay. I thought you were saying intel bins retail higher than tray.The retailers that get them. You think a retailer that receives an open tray of CPUS won't test them and see which overclock the best? Especially if said retailer then specifically sells binned and garunteed ghzs chips for a premium??
Weird, something wrong in their testing I should think.
They managed to oc with ‘ease’ all cores to over 5.2 yet ryzen beat it in deus ex, and the oc made performance worse in one of the cpu benchmark tests.
Seems strange.
What we should study is the C15 (and Timespy), the poor 2700 does 1554 against 2238 of the 5.2Ghz 9900K with AIO.
However a 2700X @ 4.3 (most AIO can do it, even with wraith can be done) does ~2000.
So at 21% higher clock speed is barely 10% faster in something that shouldn't have issue with?
No wonder PT/Intel rushed out the benchmarks and crippled the 2700X on both to catch headlines.
Total rubbish.........STOP TYPING THIS ON THESE FORUMS OR LEAVE!!!! we only bin systems stocks for the final time...........Where do you think they get their golden CPUs they sell "5.2ghz" at a premium etc. From OEM trays of course. They aren't going to open up retail boxes to do it. Meaning if you buy a OEM chip you can be assured its not a good over locker or it would be sold as golden.
This is certainly not ideal as you should aim to keep as many components the same as possible. However, they were only testing the 2700 at stock as a comparison. In which case the wraith wouldn't be a limiting factor. If they had been going head-to-head with an overclocked 2700X then it would have been a different matter.The wrong with the testing is they used 2700(non X) with wraith cooler, against the 9900K with 280mm AIO.
I think there is probably some truth to this. Intel obviously have their eyes on the 2700X which for the most part comes factory-clocked to the max. Sure you can go higher with both, but it will require high-end boards and cooling, which soon becomes a case of diminishing returns.That means, the chip overheats A LOT, and out of the box is as fast as it can go. And this is shown on the last paragraph.
