- 6 Jan 2013
- Rollergirl
Anyone noticed the double tap to wake function stopped working?
No, but I have found it a little flaky now and again, since the latest update maybe. I think it when the phones been asleep for a while.Anyone noticed the double tap to wake function stopped working?
Mines working perfectly.Anyone noticed the double tap to wake function stopped working?
Any idea if XL is in stock. Noticed both CPW and Mobiles.co.uk are now both OOS
Wanted to grab a contract bargain and have been holding out.
I already have a non XL that I was going to give to the wife
Cannot even check as it's no longer on their siteMost stores have 1 left.
I can check stores if you tell me which ones are close to you and what variantCannot even check as it's no longer on their site
Bh6I can check stores if you tell me which ones are close to you and what variant
Unfortunately poole Falkland square is the only store
Thank you, wonder if it's available to any contractUnfortunately poole Falkland square is the only store
Can you check for me with postcode CF72 please?
Any luck with this one? CF72sorry I'm not at work nowI'll check tomorrow if I remember.
They have stock of the 2xl 64gb in blackAny luck with this one? CF72![]()
thanks for checking, do any stores have the 128GB left?They have stock of the 2xl 64gb in black
Cf728lw store
