Just bung it in as is and test it with the stock cooler first.
Will get it tested tomorrow, though by installing the water-block the warranty is out the window AFAIK...
Will get it tested tomorrow. But by installing the water-block the warranty is out the window AFAIK...
Better to contact Nvidia directly and find out, someone on hardocp got a response from their CS saying as long as the PCB isn't damaged it was fine. But he was based in America and their policies likely differ to here.
Rushed release, no stock, exorbitant pricing, useless feature set, and faulty memory...
Nvidia the way you are meant to be played![]()
Bet anyone who water cooled theirs is feeling nervous right now ^^
https://tyrone.tech/nvidia-shipping...dRn-LWvTBDhE5eJi6FevZc256S9jKG20q_p1yGrV15a60
So its reckoned to be gddr6 issues, freaky looking strobing artifacts in the vid.
People with problem tech complain the loudest on tech forums. This has always been the case. You wont see people with working cards going out of their way to post about how they are working as intended. Outside of enthusiasts that would be posting regardless of course.Is this been blown up or do a lot of RTX members have issues?
Thats not to say the problem isnt real.
Swap to the other team!I recall shortly after launch a thread on Vega 64 LCs failing badly as well. Mine failed also. After replacing the rad fan with a more silent model, no more bearing grind could be heard and a driver update the next day solved the instability issues.
This seems no better or worse than this, only there are a lot less people on this thread advising to swap to the other team!
Yes I don't know if it's a bad batch of RAM or perhaps rushing the cards out the factory to meet demands. Either way, it's totally unacceptable on such an expensive item. I really feel for anyone who's watercooling and suffers these issues! Was looking to do the same myself, so I would want to be as sure as I could that I was getting a solid and reliable card. Not that you should even have to THINK about that on an £1100 product!!
Not so much:
- This will be an advanced RMA and through this; you’ll first receive a replacement unit from us.
- Defective part/unit needs to be “returned” after receiving a replacement unit.
"Buy Nvidia GTX2080 & get Space Invaders included FOR FREE onboard the GPU!!"
