Let me try thatInstall Nova Launcher + the Google Feed addon. Works on my 6 anyway.
look at john lewis. Got mine from them, next day delivery and same price as OP.
Regarding No Notification Light.
I found a workaround.
I will try it on my Oneplus 3 . It has a notification led but I can try it out and see whether it'll work well on the 6t.
https://themrphone.com/article/oneplus-6t-no-notification-led-workaround
I have the oneplus 3 and love the OS.
I would get the 6t, I love the look of it with the teardrop notch... However I'm thinking that having no notification light is a deal breaker..
How are all you users of the 6t getting on with not having the notification light??
Is it a case of being a deal breaker to you too?? IE. Sending the phone back?
Mm without a notification light and always on display how do you know if you've got a message?![]()
Yeah that's not a OnePlus thing, it's Android Pie. I kept getting those messages on my 2XL after it upgraded to Pie.Phone goes beep, I expect they'll cave on AoD.
One thing that's been bugging me is it keeps asking me if I want to turn off notifications on a certain app because I keep dismissing them but I'm dismissing them because I've read them. Very annoying.
What is the general consensus on the pre-applied screen protector? I generally don't use them and have fitted maybe two or three in my time only to remove them within a month. That being said since it's factory fitted I'll probably let it run its course and keep the screen pristine for a while at least. It also appears to have some slight anti glare qualities that I've noticed with the strong sunlight this morning. It's definitely much easier to use than my 2XL and I don't think it's purely down to brightness.
Got another hour of screen on time by time it got to 15%. 7 hours is reallllly good. Hopefully stays like this as battery life was always the #1 thing that annoyed me about mobile phones.30 hours since last charge.. 6 hours screen on time...battery at 30%. Amazing. Won't be sending anything back.![]()
My understanding is OP don't fork out for the testing and confirmation just to obtain a certificate to make it official. It is waterproof in all but name. Matthew Moniz did a great video showing off the waterproofing prowess of the 6T.Can someone explain, or link to explanation, of the waterproofing situation? It has no IP rating, but is waterproof?
