Is that a planet
Lorville is a City on Hurston, which yes is a planet.
Is that a planet
Hey, that's most helpful and decent of you.Just found the updated TOS with Refunds
But that ain't out yet in either live or ptuLorville is a City on Hurston, which yes is a planet.
EFT are testing itAnd I don't need to, I hope?
Stanton? Levski?
If those are new locations, then I don't even get that far...
I wake up and amble out into the EZ-Hab, go fetch one of my ships, bimble out to the landing pads and usually quit in frustration by then.
Potentially, but I was only peeking in to see what was new. Capping a vid is way too much hassle just for a minor curiosity.
If there's no obvious setting that needs tweaking, I'll just wait until the completed release....
It's on my 2TB HDD, as my C: SSD is only 120GB.
However, it always used to run perfectly fine from that location previously. Not sure when I last played, but Star Marine had been out for a while. I knew there were some problems with a subsequent update, but never looked into it.
Pointless. It's only 50 quid. You will probably waste that amount on booze lolOk, thanks guys.
It's only 50 quid but I'd rather have it back.
I'll decide if it's pointless, thanks.Pointless. It's only 50 quid. You will probably waste that amount on booze lol
everyone has different circumstances.I personally had to remove it from HDD and go to SSD as i was getting stutters. However, im not 100% sure that it will be the definite cause. I could be worth a test but i can't promise it will be stutter free.
Please note this smooth install is also running on a three day old windows install![]()
I run it from a mechanical drive also and it works ok. Hangs a bit just now an there, but is acceptable.
[email protected] in Port Olisar is pretty much maxed out (still pretty smooth), even limiting a bit an OC R290 @1080p medium settings (or high, can't remember now), hence my question about Ryzen - more so since Chris said at the latest presentation that Threadripper was very fast.
It stays about 40fps+ from what I've tested there (where is more busy in the station), other than that, can reach 60fps+ with ease in less taxing areas of that station, universe, a planet I've visited, etc.
.Ok, thanks guys.
out end of next yearAny word about Squadron 42?
have u even tried 3.3 yet?Ok, thanks guys.
No, don't want to either.have u even tried 3.3 yet?
If I've lost fifty bucks fair enough, no one forced me to back it. I'd rather claw it back of I could though. I've no interest in StarCit anymore.
