I guess could be better. Cant really fond othwr vednors temps to compare.
Pubg 1440 UW temps go above 80 with fan around 80%
Other games can stay around 75 with fan auto
Yes its mine.
80c with that massive heatsink on it? wtf.
Yes its mine.
Well if you put your fans in case up it will stay around 75C but I am running UW monitor 3440x144080c with that massive heatsink on it? wtf.
Well
Was going to buy this because of its amazing looks but then I saw a review that found its noise and heat output mediocre.
Glad I bought the Strix, it's consistently topping the charts for heat and noise everywhere.
Can you please tell as more details about temps and fan speed ... etc .. thinking about buying Strix maybe ..
The Strix has dual bios - 'performance' and 'quiet'. There is a physical switch on the card - all they really do though is change the fan curve.
Performance doesn't go above 65 degrees and is around 50% fan speed at that that temperature.
Quiet - I haven't bothered testing because performance is quiet enough for me, and believe me I hate noise. According to reviews, it never goes above 75 degrees in this mode and it really is close to completely inaudible.
From a heat / noise perspective this card is much better than the Strix 1080 Ti I had before.
3440x1440, I have 'advanced' version whatever that means. Ultimately it's luck-based how high your clocks are. I got a great card - it clocks around ~1900mhz at 65 degrees at stock settings. I don't know about VRM temperatures.
The build quality of this extreme is not great to be honest, it looks lovely but compared to my 1080TI palit game rock it feels so plastic and cheap. The whole front is plastic and not a good quality one too. My brother brother bought one but it looks amazing to the point i would even put up with a loud fan lol but not paying the price for one.
On a sidenote does anyone know how to enable RTX in Shadow of the tomb raider?
Shame. I haven't actually yet tested any games with RTX on yet but then and again not many games have RTX.Don't think the update for that is out yet.
Honestly, plastic is better than the paper thin metal they went with last time.
Hello I find plastic shroud very qood quality and strong not bending. I like it.Fair point i suppose, but for £1300 i would have really expected better material.
does anyone here have bad coil whine? Would really appreciate if other owners would have a listen to their cards to see if they have coil whine?
this 2080TI has terrible coil whine, we ran Heaven benchmark and its quite audible.
on wolfenstein its bad but on the menu screen its how shall i describe it, like strangling a cat while its clawing a blackboard.
I suppose its return it for a replacement, i have a feeling not accept a replacement card this side of Christmas.
any truth to " if i run a benchmark for few days non-stop it will fix the whine or reduce it"?
There is no coil whine on my sample But I had it on my previous cards. If you run card in load for a while it can improve. In Wolfenstein menu you probably get really high Fps there.
Try to use some fps Limiter
You get Coil whine when Fps is very high only
