Looking in event viewer I’ve loads of NVLDDMKM errors.
What overclocks has everyone managed?
I have 150 on the core and 850 on the memory. 64c with 58% fanspeed.
this has to be the worst card I’ve ever owned for problems So disappointed .
What ? Do you have this with Aorus rtx 2080 ti ? That is impossible![]()
I was more about Temps at that 58% fan u said. Nobody here can achieve that result.. people are here getting 75C and that is with 70-80% fan ...150 wasn't stable in every game so I lowered to 130 to ensure stability in everything. But yeah that's what I'm getting roughly. The GPU temps and core clock change a lot in Hitman depending on how demanding the mission is. On one of the missions I'm stable at 2025 MHz with 0 dips. On another I dip down to 1965. I'm not sure what it is, it's very peculiar, I'm guessing it's CPU bottlenecking cause I'm not reaching the temp or power limits.
It varies so much on Hitman. Depends so much on the scene.
What resolution you playing it? So are you using your own fan curve or u keep fans on 58% give me more details..
So much for perfecting the GPU.
To be fair it's a very very hot chip.
It's been a problematic release for sure, it doesn't appear Gigabyte have an adequate cooling solution on this card.
Aye. It's adequate but not good. I can see why the FTW3 and Strix are more expensive. Makes the trio an absolute bargain compared.
