- 3 Feb 2012
- Bath
I bought an Element Gaming 27" 144hz freesync 1ms 2560 x 1440 monitor recently for £229, it's flipping amazing, i can't say here where from but it's easy to discover.So, Vega 64 owners, what monitor have you paired with your card? What are some of the best FreeSync panels to pair with the 64?
I ask you in return, where can I get a decent price vega water block for a reference card, they are all out of stock, end of life, end of production in my usual placesSo, Vega 64 owners, what monitor have you paired with your card? What are some of the best FreeSync panels to pair with the 64?
I am looking for the full cover waterblocks for my reference 56 but i cant find them anymoreI'm still using a 35" VA, super-wide, curved 160hz AOC monitor I picked up massively discounted a few years back (like £300 off). It's only 1080 but I find it fine for gaming on tbh
Other than that, an Oculus Rift.
You can only get full cover waterblocks for reference cards, no one makes any for the others
Might be able to use a universal block and ramsinks, but it needs to also cover the HBM2 chips which are only a couple of mm from the GPU itself. It's difficult because the card isn't really the "standard" sort of layout.
Reference 56 = 64 for design so any Ref 64 block should work. I'm running the Aquacomputer block and it's been pretty damn goodI am looking for the full cover waterblocks for my reference 56 but i cant find them anymoremaybe someone has one hanging around.
Indeed, I'm looking for one but like I said they are becoming un available or out of stock everywhereReference 56 = 64 for design so any Ref 64 block should work. I'm running the Aquacomputer block and it's been pretty damn good![]()
Owners thread got a bit of a spurt on now![]()
Hi all, my nitro+ has been running nicely for a week now and just got my ASUS ROG 35 widescreen yesterday which looks fantastic on destiny 2!
So need to start over locking or undercoating. What’s best software to use to check performance now for baseline before tweaking? And what’s the best resource to follow to optimise it as not 100% sure where to start.
Thanks in advance
So I have an odd combo here. Two amps and one DAC. Schiit Audio Modi 2 uber that feeds either my DT990 pros with the Magni 2 uber amping them or I'll run my Micca MB42X bookshelf speakers amped by an SMSL SA50 amp. Either way I never really need to turn up past about 50% gain or so as it's perfect around there. Very crisp, loud, clear, and didn't destroy the bank. Had these for a few years now and still no complaints
