Are you doing anything with Hue?
5 Mar 2010
Close! Thanks very much. This is really exciting, I've wanted to replace some crappy xmas type lights behind a unit with something I can integrate into the rest of the smarts I've got going on.
Would something like this work? Basically I want something warm white that probably stretches to about 15m so can I daisy chain these? Do I need to buy extra of those 4 pin connector things? etc.
Thanks!
Did you order these in the end Matt?
Caporegime
21 Oct 2002
Here
Hue Cher ceiling lamp fitted in dining room. Expensive at £186 from dmlights in Germany but looks good and puts out a decent amount of light. Although I thought it would be brighter at 3000lm but I guess that’s on the colder temperatures where it is very bright.
The switch also comes with it and seems good quality but still think I prefer to go with switch’s on the wall that can also work with the hub as a system. The remote can still come in use to sit on table. Pressing the on button also cycles through the preset warmth’s
Harmony hub on the way now to link up with the rest of it. I have a nest but waiting for a good deal on a nest protect.
Last addition will be WiFi plugs to run a few cheap gu10 bulbs on a dedicated circuit.
Then it’s going to be fun getting it all to work properly
1 Mar 2010
I have not yet bought into the Hue ecosystem and am waiting for an app controllable conventional led dimmer, for regular led (high cri) dimmable bulbs,
there seems a big market gap ... varilight don't have one
But noticed amazon have these
any thoughts ?
4 Dec 2002
Bourne, Lincs
any thoughts ?
Guy in work bought one, but as he didn't have the neutral needed in the back of his light switch, so would be work checking if you have that before buying
18 Oct 2002
Sutton Coldfield, Birmingham
Having had a fairly major move around with rooms, I decided to use just the Home app in Apple to setup automation etc.
Why have I not done this sooner? It's so much easier to use than the Hue app and there are so many more options.
Going to grab some Eve smart plugs as well for the Christmas tree lights.
Just wish my Nest stuff was compatible.
17 Jan 2005
Liverpool
What about the Lightwave kit? I originally wanted to go that way but my back boxes weren't deep enough in my walls and I really couldn't be bothered to make them deeper so ended up going with Hue.
9 Apr 2007
Just wait for the hue branded version of the Feller, Niko and Vimar. Sure at least one of them is powered by the act of switching so doesn't require a neutral.
1 Mar 2010
Yes - lightwave switch ~£50 + their hub £50 is a solution , but like varilight without a neutral wire I don't know whether they can dim successfully to low levels, or like varilight, you have to insert a dummy load.
I prinicipally want to control led uplighters, that do have a neutral, and I can put a trailing back-box in-line on mains cable.
Yes, I did not know, that is interesting now watched the video
so they will remove the need for a hue bulb - that's good, although looking at Niko web-site they do not have a pedigree for led dimming just incandescent, so far ...
Sonoff who already have a good wifi switch need to democratize the dimmer market too.
9 Apr 2007
No pretty sure you will still need the bulb.
31 Jul 2004
Surrey
any thoughts ?
Just out of curiosity, how come CRI is such a big deal to you? I just had to google it to even figure out what it is!
I did try lightwave for a triple gang switch I have controlling 10 bulbs.. it was sooo expensive and then when I got the hub setup, I shelled out £100 for the switch, then realised it had a slave off that socket for an outside light with the switch over the other end of the room which would have been another £50ish even though I didn't want smart control over that and then the nest of wires behind the triple gang put me off so much I just gave up.
Now I have echos in every room I want to control lights, I have them set to knw what room they're in so I can just say "alexa turn the lights on" and she knows what I want and then "alexa set the lights to 50%" or whatever I want.
Never need to touch a switch and I bet it still cost less than lightwave.. if you're not well experienced I'd steer clear.
I mean I work in IoT, I've built PCs for years, I know my way around a youtube guide.. I still bottled it.
