The car was a pre reg. I didn’t set out the buy an x6, I had bought an M4 but the deal on the X6 was insane so swapped to itIf the car is new I am surprised you didn't spec it, it's much cheaper than adding it.
Subscription carplay seems absolutely bizarre. What an odd way of doing it, its not like anything is provided via a server etc like RTTI![]()
BMW have 0% APR on 4-series
You presumably already know this, but this is likely because its one of the few cars left on the old F Series platforms first seen in 2008. The 3 Series has recently ended production, I'd imagine the 4 isn't far behind it.
What are peoples thoughts on the M4 Competition Pack? Looked a new one yesterday as BMW have 0% APR on 4-series but even with some pushing it's still a car likely to lose £40k in 4 years which doesn't really appeal so I took a 1 year old one out today which should see closer to £20k in depreciation over 3 years (still not ideal). Looking as a replacement for both 5GT & Evora, was impressed with the ride given all the reviews state that it is shocking, engine felt good (though didn't sound great) but couldn't really push engine or handling given it was damp, greasy and cold and the M4's do have somewhat of a reputation!
The roof is bonded in and stiffer than metal, not sure why it would creak. Mine doesnt
hiya, about to swap my thermostat around in my e46 m3 (2005) and rather than do a full engine flush, just going to replace the lost coolant,
I was about to order comma g48 green, but after looking at my coolant, its definitely blue.
all I can find from the service history is B83.51.2.355.290 1.5ltrs
what coolant would you recommend?.
Can be very skittish in the wet and they sound flat, but look good, go like hell and drive well. If you're worried about depreciation I wouldn't go anywhere near a brand new one.
You can currently get 2017 models with 10k miles on the clock for ~£40k. They still are under manufacturers warranty, barely used and have already done £25k depreciation in 18 months. In 3 years, a £40k M4 will be with about £25-30k I reckon.
I found the M4 CP very underwhelming to drive. Really poor turbo lag and sounded so disappointing. Felt great in corners and felt nice to drive when not gunning it, but it was just extremely disappointing. Luckily I test drove it properly after BMW initially took me on a very poor test drive which didn't show much of the car off at all, as I was quite close to pulling the trigger at first but thankfully didn't.
Also, the carbon roof was ridiculously noisy. Both of the drives, all I could hear was creaking and a rattling type noise from the roof. Was infuriating.
The M3 I test drove did exactly the same as well![]()
