G48 is officially blue/green so anything G48 will be Ok
Thank you, I'll order a bottle.
Did the traction control not cut in?Just had a brown trouser moment on the slip road in the M2. As I was joining the motorway, must have put my foot down a bit too much for the conditions (tires may have been cold as I had only set off 10 mins before), it felt like the back end of the car snakes about 1 metre side to side. God knows what the car in the lane next to me was thinking.
Clearly I haven’t quite got used to RWD life but the greasy conditions probably did not help.
This car seems to attract idiots though as the car in the other lane was so eager to push on from the lights I thought it was going to crash on the corner.
I seem to attract some idiot on a daily basis, usually someone tailgating me for no reason. I really don’t understand it.
It is bonded in? How is the metal roof fixed?
I still can’t understand why the roof would creak. Maybe it’s bits of trim near it creaking.
I’ve never seen it mentioned and google suggests it’s never been mentioned before
Oh and this weather you have to be very smooth with throttle
From memory the metal ones are welded. I'd hazard that what's creaking is the roof against the internal supports. I don't believe it's bonded to them.
No idea on that series M car, but I know when I had the carbon roof fitted to my E46 the metal roof was riveted and sealed on, don't recall any welding as Geoff Steel had it off in no time by drilling out the rivets, though those rivets could have been welds, I really can't remember sorry.
They bonded carbon roof in, its never creaked or leaked.
The only creaking in my car is normally from the false rear interior and parcel shelf area but for a track car all in all its pretty quiet.
They'll have been spot welds. Nice and easy to drill out.
I’m guessing you lifted off the gas completely which more often than not results in quite a violent “snap” in the other direction...
Reducing rather than lifting off completely is the better option.
If your not used / confident in RWD then look up a skid pan course and get yourself on it, I did one years back (in a truck) and it was undoubtedly the most useful thing I’ve done behind the wheel.
It won’t turn you into a driving god but it will prepare you for the unexpected and how to counter it.
As for the cretin behind you, sod him, your in front let him be as eager as he likes - once he’s past you - never allow yourself to be effectively driven by the fool behind.
I'd guess you'd left Sport + on without realising it - and it will bite in such conditions in that mode - my sister astounded me when she first took me out in their M4, shes as unable a driver you could wish to meet yet the way the car masked her inablity to use the M4's power in poor conditions was nothing short of remarkable!I've been testing the car out tonight as it was really bad rain, lots of standing water on the country roads. Obviously trying with no one around and with plenty of space, I had the car in comfort mode and floored it from 10mph. Traction control kicked in but it still went fairly quick, no signs of the rear feeling unsettled like it did last night.
Thinking back now shortly before setting off last night I was toggling the different modes comfort to sport then sport plus and back again etc. Perhaps I left it in sport plus without realising which is traction control mostly turned off, or even sport mode which allows a little slip and is a bit more lively. There is no M buttons in the M2 (only now available in the M2 comp) to customize the drive settings, its basically all or nothing.
You're right though I need to get on a skid pan day.
Looking for a new towing car. 2015 330d touring m sport x drive is top of the list.
1. Quite a difference between the 320d and 330d with regards to oomph. Even though primarily for towing, it'll be my daily. Is the 320d pokey enough or quite lazy?
2. Not really familiar with bmw option list, what are the must haves? Heated electric fronts would be one option I want.
3. Milage. Not a great difference in price between 30-60k on the clock. How are these price wise on official servicing? What intervals are the majors at?
