Caporegime
- 11 Mar 2005
- Leafy Cheshire
No, and why would they, they aren't even there
Interested that you know the operational locations of the SAS, you must have some good connections.
(in the same way hobbyists used to use the old thick walled ice cream and butter tubs for electronics projects)Change the law to allow it to be shot down perhaps?
Somewhat insane that currently they can't as the law prevents such responses.
What did you say?![]()
That looks like it's possibly either something that is prototyped, or has had the box bolted on to hide what's inside.
Either would make some sense depending on the situation as roofboxes are handy for providing a (semi) sealed enviroment for gear that has to be carried on the outside of a vehicle, it's also a good way to hide exactly what is in use if you don't want to give any clues away.
It also gives whatever it is some level of streamlining which is a good idea if you're putting stuff on the roof of a vehicle (it protects it in transit and helps reduce drag etc).
IIRC quite a few companies have used similar roof boxes to house electronics, as it's far cheaper than developing your own completely custom box and you can get hold of them easily(in the same way hobbyists used to use the old thick walled ice cream and butter tubs for electronics projects)
What would your suggestion be, based on your apparently huge knowledge of what other countries would do?That's fine, i'm sitting here humored by the idea that we should do nothing.
Very British, the bestest.
SOMETHING, anything at all would be better than this.
We must do something! This is something! We must do this!
They are clearly doing something though. What more would you add to the something? What would other countries you mentioned do in addition to the something we are already doing?SOMETHING, anything at all would be better than this.
They dropped this idea due to injuries to birds:
