My 2500k is on its final mission strugglling vastly now i have added a vega 64 .. Will be getting a 3700x on day one .
Yeah my 2600k is pretty must at 100% usage in any game now with a 1080. Still surprisingly smooth though.
But yeah, Zen2 ASAP
But yeah, Zen2 ASAP![]()
So is the best Guesstimate for thease still Q2 next year?
That's exactly what I'm finding. If set resolution scale to 150 which seems OK.Yeah my 2600k is pretty must at 100% usage in any game now with a 1080. Still surprisingly smooth though.
Late Q2 I'd say, June'ish is a good bet.
good, just about enough time to build up some money in the upgrade pot![]()
Ces in a couple of weeks . I think info will slowly apear after that? Hopfully!Should be, a leaked engineering sample would be nice, there was one back in September/October and since then, no news. https://www.techradar.com/news/amd-zen-2-leak-points-to-a-cpu-with-8-cores-that-can-run-up-to-45ghz
A potential leak of the specs of the 65W TDP 8C model:
https://twitter.com/KOMACHI_ENSAKA/status/1077041301210591232
A 500MHZ base clock increase over the Ryzen 7 2700.
I would say that's the Ryzen 5 2600 replacement.
Interesting. So:
+300 MHz
+15% IPC
+4 threads
Can be +50% performance overall in the end.
I'm going to be a little more pessimistic about the IPC, i'm going to say 10%.
I am conservative on the +15% IPC. AMD said that Zen was the worst case scenario, also with Zen+ the IPC barely moved at all. If they take all the low-hanging fruit and work on double/triple/quadruple some of the specifications, it might be completely possible to get +20% IPC.
Look:
Before this gets Chinese Whisper warped into "AMD Said +20% IPC Zen to Zen 2" none of these slides indicate that, as a matter of fact AMD were quick to say the leaks of 29% IPC gain were very specific workloads, altho there would be an uplift in IPC it wouldn't be anywhere near that touted 29%.
Look, AMD made a massive leap from Excavator, 52%, its actually over 70% vs the one we all know, the FX series, Vishera/Bulldozer..... but it was an improvement from an architectural mistake AMD made 5 years ago and could not afford to put right quickly, inventing new architectures costs a huge amount of money and takes years.
Don't expect any dramatic up lifts with Ryzen 3000, its an improved version of an existing architecture, and you know what? in a fight vs Intel its enough to match them in per-core performance for a lot less money and more cores, that's great.
The slides indicate that AMD beats its plan. If they plan 10-15% IPC, it may turn in reality more. 10% IPC is not that much for such a full die shrink.
Also, it is never great to play the catch up game with Intel - Intel hasn't even moved yet to 10nm and when it happens, guess what - the performance crown will again be theirs and people like @easyrider will buy the i9-9900K replacement.
AMD needs the absolute performance crown.
