...chiplet...
...chiplet...
...chiplet...
Inigo Montoya said:You keep using that word. I do not think it means what you think it means...
...chiplet...
...chiplet...
...chiplet...
So when can we expect to see these in the wild? Are they previewing at any of the early 2019 tech shows?
Newbies are generally made to feel very welcome here in my experience. Of course this depends on their agenda in joining up.
hmm, bang on his leaked spec if that's any indication... potentially bodes well for the rest of the info.
Exciting times!
Nah it was obvious mate. AMD announced it 2 years ago in their roadmap.
Oh right, silly me.
Or, more specifically, if you'd actually been following the tech press surrounding Zen for the past few years you'd be fully aware of what Intel said, the context in which is was said and how the "glue" insult has become a gag. But I guess you missed that by cherry-picking random pieces of nonsense to continue pushing your non-argument.
Don't worry though, keep those posts coming; only 982 to go before you can get to the member's market! That is why you're spamming tripe, isn't it? Isn't it??
And No, i didn't even know there was a market place.Keller doesn’t hint at the most important component until near the end of the 15 minute session when he mentions a next generation “fabric” that would be found in every CPU from mobile devices up to servers and that would allow AMD to scale performance at an enviable rate. That fabric would be known, by 2017, as Infinity Fabric.
He explains that the fabric would allow AMD to employ a “chiplet” approach to design. Instead of building one processor on a single die AMD could package a series of processors together—connecting them via the Infinity Fabric system bus.
Oh right, silly me.
3700X is I think where my dolla will be going most likely so looking forward to seeing confirmation on that one.
A retailer has apparently leaked the specs of the whole range:
https://videocardz.com/newz/amd-ryzen-9-3800x-matisse-listed-with-16-cores-and-125w-tdp
3800X for me, will likely need never upgrade again![]()
